Scott Drake C6DZ-10884-B temp sender
Started by shelbydoug, February 03, 2020, 08:04:46 AM
Doug: Did you check your voltage regulator? I had one reading 7.5V. Fuel gauge and the temperature gauge also read high, even thought it wasn't hot.
Yes. I think it was either 5 or 5.5v? I don't remember since it reads about right now and no need to reopen that case. Just under 1/2 with the thermostat just opening at 192. So I'm happy with it.
It's a Motorcraft unit.
It seems to be the consensus here that it is the after market senders not being calibrated properly or they were all standardized to the wrong number?
Bossbill
They aren't giving these away, are they?
On to the next grossly overpriced item on my list.
70 B302   6/6/70  0T02G160xxx
