69 GT350 dash printed circuit replacement
Started by SChatman, May 28, 2020, 11:42:06 PM
SChatman
When replacing the printed circuit, do the washers go on top of the circuit directly under the nut or screw? It seems logical that way to keep the printed circuit from twisting as ithe nut or screw is tightened but I wanted to make sure and I can't find a diagram or Manual that tells.
Thank you.
SChatman
I can't tell if the washers are on top of the printed circuit or underneath.
