Original grill
Started by kram350, March 02, 2018, 11:07:32 PM
kram350
I have two front grills, on one the edges of the horizontal bars are flat when viewed from the end of the grill (off the car) and the other has an angle cut that reveals more of the slat. Which is original or are both original? All the rivets are the same on both. Thanks
Quote from: kram350 on March 02, 2018, 11:07:32 PM
How about a picture or two?
GT350Lad
6S373
6S1276
deathsled
Interesting question.  Looking forward to answer myself.
Engine revving to disturb
kram350
Thanks for posting some pictures. Not the challenge is to find some just as detailed from original cars and service replacement sources as well as reproductions to compare.
On the one with the flat fins, can you bend the metal easily with your hands?  If so, would be an indication that it's a reproduction.
Rocket
The grille on 6S550 has the flat cut ends, and is the original grille. Ron
kram350
Neither grill will bend without effort and then both spring back to original shape. To deform either, they would probably crack and break.
SFM6S1348
#10
6S1348 has flat cut edges.
I have to add it looks like to me that the edges are slightly rounded and not perfectly flat.
...found 6S1348 after a full year of searching. It was in a garage I passed every day on the way to work. I looked at cars in front yards, back yards, storage garages, in fields, and under trees. I found a 65 that had hit a tree and was bent all the way to the back...
kingchief
What are the rivets on an original grille?  Are they like a cap or with the traditional hole?
Steve
SFM 6S406
Quote from: kingchief on March 12, 2018, 03:03:13 PM
Steve
They have a curved head surface with no hole. The pop rivet type with a hole is a easy tell for a later service replacement.
kingchief
Thanks guys AND photos too!  Yeah!
Cheers,
Steve
SFM 6S406
