Recommended vendors for rebuilding calipers, master, steering setup, carbs
Started by BeaterGT500, October 15, 2020, 12:29:48 AM
Quote from: Drew Pojedinec on October 18, 2020, 07:15:53 PM
I'm here too 😃
Sadly I'm gone this winter, will be back in Feb.
I'd be happy to help, but obviously that might not work with your schedule.
Either way, sounds like a fun project, good luck!
^^^Worth the wait. My Advice? get in line now.
BeaterGT500
Thanks for the replies, everyone.  I'm sending Dan at Chockostang all the steering parts for proper  rebuild.  As for the master cylinder, calipers, rotors, upper and lower control arms, coil springs and perches... thinking of using all new parts from either Opentracker or someone else, and boxing up the originals.  All the original parts are so pitted and worn, I fear I'd be double or triple invested in restoring them vs buying new parts that look stock but perform better, and my goal is to drive the car not trailer it around.  I can't be the first guy in this situation, and on a budget.  Appreciate all the help from this gang!
