High Zinc VR-1 Motor Oil ?
Started by oldcanuck, November 02, 2020, 11:27:09 AM
Relicdog
I use VR1 10-30 racing oil an I add Cam Shield every oil change.
Relicdog
427hunter
I have always run 20/50 vr1 - Just recently I found that Lucas hot rod oil has a lot more zinc, next oil change I am going to try Lucas.
Inigo Montoya
Jackie Brown
   Be careful , too much is as bad as not enough. The excess ends up as a film on the bottom of the pan.
oldcanuck
Thanks to all that have responded.
I have been using a ZDDP additive on all 3 of my cars, with 3 different viscosities that they require. 10W30 in the GT350, 10W40 in the L-72 and 20W50 in the Duetto.
I know easier is not always better.... maybe I should just stick to what I have been doing in the past.
Bob
Knoxvegas, TN
EdwardGT350
checkout joe gibbs driven oil. adding zddp is not always better than having it already in the formula.
1966 GT350 6s1761
