Inspection Sheet of Some Type
Started by TXShelbyman, March 25, 2018, 08:41:41 PM
TXShelbyman
I found fragments of some type of inspection sheet in my GT500. Does anyone know what it is?
Looks like it might say Repair Inspection Card
Thanks!
When things go bad just hit the throttle, may not solve the situation but does end the suspense.
Formally watts428
yep i have a complete one / these were used to note defects and repairs needed after assembly line  inspection
TXShelbyman
Formally watts428
Some times referred to as a "Travelers" inspection sheet. They are specific for each area or part of the car (body and paint, electrical ....)  and were used when there was a issue or problem. The inspector marked the section and identified the issue, "missing nut, dirt in paint, fan not working, and then the car would be fixed at some point. Sometimes rather than getting tossed in the trash workers tossed or tucked it into the car. There was a spot on the form for the cars rotation number to identify the car and the issue either initialed or stamped with an ID of the inspector
have maybe 2-3 dozen from different cars
