Bendix Master Cylinder
Started by capecodmustang.com, February 11, 2021, 11:42:08 AM
capecodmustang.com
Does anyone have a part number for a 1966 Hertz Master Cylinder?
Bendix?
# 222...????
Thank you
KR500
Bret
2225032 is cast into 3 M/C's I have.
Rodney
Quote from: KR500 on February 11, 2021, 12:25:18 PM
Bret
Rodney
That is the correct casting number.
capecodmustang.com
Thank you...
Found one in a trunk of a project..
Couldn't read the number....
Bret, not sure what car # you are working on but there is early and late MC. Plus there's the mico......
Rukiddin
I just want to add a choice...
Quote from: Rukiddin on February 11, 2021, 04:26:11 PM
That would be the early version.  For some the dating may be important also. You'll find it at the base of the master cylinder where the cap retainer clips into. There is an early and later date code pattern also
Has anyone correlated if the date pattern change correlated with the the change from brass flare adapter vs. flare fitting made into casting or not?
Quote from: Bob Gaines on February 11, 2021, 05:54:39 PM
On my part I'm still collecting data points and examples as part of the 66 Running Changes thread over on CMF. Its close but can confirm right now that its a direct match
Would be interested in additional examples with the date and which threads a unit has. Might be a good start of a new thread
This is not documented nor in anyway scientific but I've always thought it was around time motor mounts changed over
