Clutch disc stuck to flywheel ?
Started by Tired Sheep, May 24, 2021, 05:07:24 PM
Tired Sheep
Car sat used is there a way to separate the disc?
GT350DAVE
That happens. Start it in gear and it will brake free  in 20-30 ft.
Support the SAAC Registry
Quote from: GT350DAVE on May 24, 2021, 05:45:05 PM
+1 . Hopefully you can point it in a direction that gives a fair amount of room . I had one that took about 50 ft or more to break loose. Another time I didn't have too much space for a 50 ft run so just to be sure I gave it a little gas (as in trying to spin the tires) it broke loose immediately. When it breaks loose you push in on the clutch pedal and brakes.
Tired Sheep
I think that worked
It bucked like a bronco but finally broke free
     And hopefully the friction material hasn't been pulled away from the marcel plate vs shearing from the corroded flywheel and or pressure plate!      :o
Tired Sheep
A bit scary but seems to be working for now
Thanks gents
