1969 Hood details
Started by aboss4tg, November 19, 2021, 05:01:57 PM
aboss4tg
 Should the center recessed area be painted Black?
69 GT 350 Hertz
66 Convertible C code
66 Fastback A code
88 Saleen
89 SSP
If you're asking about the bottom side of the hood the black and exterior color transition on the outer surface of the hood reinforcement rails/ribs around the perimeter. Black and body color were applied before the grills and epoxy installation/application. The transition from one color to the other created a somewhat soft edge often with "blow outs" where the tape was not pushed into the corners and details in the rail
Here are some pictures from unrestored examples - Hope this helps
Hope this helps
aboss4tg
Appreciate your help,
Another question, is the center scoop opening that leads to the air filter on top of hood painted black?
69 GT 350 Hertz
66 Fastback A code
88 Saleen
89 SSP
Quote from: aboss4tg on November 20, 2021, 06:17:03 AM
Yes .
