Window adjust
Started by 67 GT350, November 14, 2021, 06:53:25 PM
67 GT350
On a 67, can the windows be adjusted to raise up higher to seal better and reduce wind noise? How?
Also, not to repeat...what about a 70?
RARE  Signature Delete
There is a stop (short stubby rubber coated bend arm if I recall correctly) that can be adjusted up or down the slot to control the upper movement. You will find this and a slot above or below it as a secondary locator
Don't have a picture. If you have the door panel and you roll the window up you will be able to feel it restricting the upper movement and that it does not touch when you roll the window down just slightly
Hope this helps
67: also a rear channel adjustment under the window seal on the back of the door.
