header support brackets
Started by shelbymann1970, December 07, 2021, 10:39:54 AM
Here are 2 bare metal brackets and 2 painted brackets. The painted ones are repos I believe. The media blasted ones look to be originals. The question is the threaded holes for the bolts to hold the header to the brackets: Should the surface area where the threaded holes are should they be flat? They are flat on the repos. On the originals they are not. The car was hit in the front at one time so do not know if that would have any affect on why these areas are not flat if they are supposed to be. Gary
Quote from: shelbymann1970 on December 07, 2021, 10:39:54 AM
I take you don't have the car together enough to fit the brackets. Sometimes you have to adjust the angle to fit up flat against the letter panel tabs. You can bend them flat now and adjust later if needed or bend them to the proper contour at the time of fitment to the letter panel.I hope this helps.
Quote from: Bob Gaines on December 07, 2021, 11:03:10 AM
Yeah the angle you mentioned might be an issue. What I am concerned about is the mounting area where the  header tabs rest on when you bolt it on. It isn't flat. Are they supposed to be flat like the repos? See pics below
It would be best that they are flat as to not cause any stress on the fiberglass when attached/tightened.  I have some flat tip pliers that work great for that kind of stuff.
Quote from: CharlesTurner on December 07, 2021, 11:44:30 AM
Thanks. I was going to drill a hole in a block(for threaded area clearance) to use on the back side  to hammer the area flat
The smooth jaw pliers are Blue-point/Snap-On (Knipex made), in 3 sizes, ADP12, ADP10 and ADP7
Super handy for flattening steel parts like this.  I use mine quite a bit.
Quote from: CharlesTurner on December 07, 2021, 04:25:47 PM
Thank you for the tool tip. I'm always looking for tool ideas for myself at Xmas time from the kids. Well the one gave me an apple watch already.  :) :). Gary
Charles do you have a pic of them? Seems they are hard to find and I have not seen a pic to know if they are what you are using. Thanks.
Quote from: shelbymann1970 on December 08, 2021, 01:17:40 PM
Quote from: CharlesTurner on December 08, 2021, 10:51:59 AM
https://garrettwade.com/product/10-parallel-jaw-wrench?gclid=Cj0KCQiAzMGNBhCyARIsANpUkzPuiAv8SlNuwOWrssO8olwL6_EitkIHc-mphyA4OmB7o9RczTVPNRAaAnKrEALw_wcB
Thanks. I saw a couple of links but OOS on those links but they were for the 3 piece set. Gary
Yeah, they are not listed in the snap-on store anymore... If I run across any for sale I'll let you know.  I think I have the ADP10 version.
tinman
MSC sells them. Here is a link to the 7" version but they have other sizes and a set also.
https://www.mscdirect.com/product/details/32997447
Mike
Quote from: tinman on December 10, 2021, 07:49:03 AM
Mike
Thank you Mike. Gary
