1966 Hertz Shelby traction bars, bumper guards
Started by louis.sciuto@gmail.com, April 08, 2022, 09:06:38 PM
Hi
I am resorting a 1966 Hertz, my car was pretty original with minor modifications.  But my car didn't come with traction bars or bumper guards.
Is anyone aware if this is correct? Did some Hertz not have bumper guards and traction bars?
Regards
Lou
Lou,most likely the parts were taken off of your car some time in the past because those parts typically came on 66 GT350's from the factory.
Hi
Doing more research and I believe some come with lower traction bars and some came with upper traction bars,  mine has upper traction bars.
GT350Lad
Must be a pretty early car? Care to share number? See a mix of both but certainly more rare on cars under 6S900 ish
Cheers
6S373
6S1276
Quote from: louis.sciuto@gmail.com on April 08, 2022, 10:55:50 PM
Hi
Given in your first post you said your car didn't come with traction bars you need to familiarize yourself with what each looks like . Both upper and lower traction bars leave installation evidence even if the bars themselves are missing.
GT350Lad
And if possible share some pics. We are always keen to see and help.
Cheers
6S373
6S1276
Yea its 6S699
GT350Lad
Very cool. It's an override car for sure
Should be brackets welded to floor behind rear seat and on axle housing
6S373
6S1276
The bump stop was also moved. 843 had this type cover (I think they were Ford big truck e brake handle boots). There were also axle limiting cables (this shot is an under ride car where the stop hasn't been moved).
427hunter
Share some photos of the undercarriage and firewall of 699 - then we can answer all your questions.
Inigo Montoya
Jackie Brown
The traction bars are defiantly override, I found them
Thanks everyone for you help.
Lou
427hunter
#12
Can you post a photo of the rearend housing and undercarriage? I am interested to see what you have there...
Inigo Montoya
Jackie Brown
