Rug-S top loader on ebay…not mine
Started by 1175, April 29, 2022, 09:19:37 PM
430dragpack
It's not an original, repo tag, typically don't see that early of C5AR case, wrong tail housing and new aftermarket input shaft and retainer.  But probably a very nice transmission to use and maybe worth it.
It would be my understanding that it should have a serial number of the car it was installed into on it as well. I don't see evidence of that having been ground off in the pictures.
It does obviously have a few new parts on it as well. Probably internally too.
The tag looks good to me and few will be able to tell for sure unless you have seen lots of the originals so I don't think there is harm done there. The casting dates need to be appropriate though to a 67 GT500 production date.
Nice original CJ versions, like the RUG-AE's, have asking prices in the 3500 to 4000 vicinity that probably aren't this clean. Then there is the shifter, the rods and maybe the gear reduction adapter that can be involved to consider as well. A rather expensive proposition as a whole.
This one is probably better suited to a "tribute" car rather then an original but seems to be priced appropriately for that application.
I'll need to read the description again but I don't remember at this writing of it saying original? Just rebuilt.
So many of the original cars lost their original as built parts in their first few years of use. Few cared at all including the Ford Service Department of installing original assembly line replacements as if that was even possible at the time.
On "restoring" a 67 GT500 there IS going to be some sort of compromise along the way on certain items. The number that are going to be original as built cars is going to be literally just a handful and even those who think that they have one are going to be embarrassed at some point to find they have replacement parts on the car.
430dragpack
Quote from: shelbydoug on May 01, 2022, 07:53:39 AM
The "R" is not the correct font and is typical of the repo tags.  The case "C5AR" casting number info is usually right up by the top of the case in '67 model year, not by the shift lever holes.  It was moved up to the top edge sometime in the 65 model year, maybe early 66 model year.  The correct, C6OR-D tail housing and C5AR-D input bearing retainer are the two hardest parts to get since the tags started being reproduced.  The C5 input retainer was replaced by the C6AR-G fairly quickly, not sure if in the 67 model year or 68.
