GT350 rear end question.
Started by 68stangcjfb, January 12, 2023, 11:28:34 AM
68stangcjfb
Did 69/70 GT350s get "N" case rear ends with 31 spline axles?
crossboss
Thats a good question. I have been around these cars for years, and I haven't seen the 1969/70 GT-350s with N cases or 31 spline axels. That said, I could be wrong....
Boss 302s, yes.
Past owned Shelby's:
1968 GT-350--Gold
Current lifelong projects:
1968/70 Olds 442 W-30
CSX4781
Best I can determine, based on my car (#362) which the rear end had never been removed or disassembled until I got it (still had the copper washers and tag installed), I'd say no. Mine has the standard case and 28 splined axles, and it is the 3.25 traction lok that it is supposed to be. Tag says 'WFB-C, 3L25'. Hope this helps.
My answer would be no based on my car having a 3.25 traction lock, no N case and 31 spline axles and being all original.
Build sheet for #2368 the rear end code is 9984AER. My build sheet is wasted in that area.
