Neutral Safety Switch Wiring?
Started by DennyD, March 25, 2023, 07:48:16 PM
DennyD
The wiring for my neutral safety switch from the pigtails on the firewall to the transmission should be secured somehow, but I can't find a photo of where the wiring harness is attached. Can someone please help. Thanks in advance, Denny
1969shelbygt350
Let me see in the morning if I can take you a picture or two
Paul
DennyD
Thanks Paul a couple good photos would really help.
The loom that connects to the neutral safety switch is typically (all the ones I've seen) through the retaining strap to the inside of the firewall location with the other loom. On Mustangs the wire, after passing or being held by the plastic strap then traveled to a plastic S clip attached to the firewall to cowl seam. The same S clips used for the windshield washer hose. Since the Mustangs being built for Shelby had the export brace and cowl support these cars didn't used that S clip and as a result had a bit more slack in the neutral safety wire and I'm not aware they did anything to deal with this on any regular basis.   Focusing on your cars production period at Ford I found a number of examples in my files of cars with in a couple of hundred numbers of your Shelby number. Does not appear that the workers always routed the wires in front or behind the throttle arm as both have been documented
Hope this helps. If we need more examples just ask
* Edited for clarity and correctness
DennyD
Hi Jeff, your photos were a big help to me. So, after the initial retaining strap at the firewall, is there any other retaining clips or straps anywhere from there to the transmission itself? Just left dangling?  Thanks
There's usually another clip at the bellhousing and I have also seen a J-clip above and to the right of the switch... goes on the same bolt that attaches the vent tube.
Without these 2 additional clips, likely going to burn up the wiring on the headers/exhaust.
Quote from: 6S1568 on March 27, 2023, 02:04:42 PM
Didn't find any pictures showing a clip at the transmission though they may have used one for some time period but I don't recall one in 66 - always learning  :) Most often I've found that the wire was simply routed between the vent tube and the case taking some of the slack up and directing the wire up and towards the center of the car.
Here are a couple of examples of the clip at the engine to bellhousing seam on the passenger side
DennyD
Thank you very much gentlemen, I'll see if I can find the additional clip.
