1967 Casting Number - Clock Code
Started by greekz, November 09, 2023, 05:12:19 PM
greekz
Need some help reading the clock code on my 1967 GT-350.  Thanks in advance.
Greek
SFM 6S1134  '67 GT-350 #2339
Blackcar
The circle of numbers is the clock indicating what time of day the part was cast. The single dot above the screw indicates day shift and the numbers 1 3 5 7 9 are the hours of the day. In this case the part was cast at approximately 8 am. The slot in the center of the clock was used by the foundry worker to insert a tool to turn the clock as the work progressed.
SFM66H
"Blackcar" - THANKS for your great explanation of how to decipher a clock code, it's more than I have ever learned before!
But now I'm confused about the dot between the 3 and the 5 - what does that one mean??
Kieth
greekz
Quote from: Blackcar on November 10, 2023, 12:12:16 AM
Thank you very much for the explanation.  It seems much clearer now.  I, too, wonder about the other dot outside the clock.
Greek
OK, I too am a little not clear, can someone (Blackcar?) identify the 1,2,3 dots and is the 4th not a dot but just a bump in the casting?
Blackcar
#1 is day shift #2 is time of day 8am 3 and 4 I don't have an answer.
greekz
Quote from: Blackcar on November 10, 2023, 11:49:04 PM
Thank you for the clarification of the at least 2 of the 4 dots.  Maybe someone else knows about the other 2 to dots.
Greek
