Color of Donohue GT350R
Started by mlplunkett, January 05, 2024, 11:42:08 AM
deathsled
Quote from: 98SVT - was 06GT on January 07, 2024, 02:28:19 PM
Quote from: deathsled on January 07, 2024, 12:33:05 PM..... photographs can and often do distort the actual color of the car as it appears in real life.  Without an actual paint code, it will be only a best guess.
Even paint codes can be useless today. Paint type/chemistry has changed over the years and the old formulas don't translate well. There has been great strides taken in the ability to scan what is on the car now and letting the computer create a new formula with new paints. The process is accurate enough to match faded areas. It's critical if doing a full restoration rather than matching a panel to scan a door jam or some other area that hasn't been exposed to UV rays.
Yes point well taken.  I had not thought of that variable but you're right.
Engine revving to disturb
CSX2601
Caspian Blue perhaps?  Or a blend of Guardsman and Caspian?
Sounds like a fun build.
Cheers
