Choke Cable Hole Size
Started by KR500, February 13, 2024, 12:10:08 PM
KR500
Does anyone no what size hole is in the firewall for the choke cable? Dumb a$$ body guy welded it up.
Rodney
Hey Rod i've got a 65 over at the other building. I can measure in the next couple days if no one gets back to you before then
KR500
tomhawk
Rodney, You are welcome to come and measure mine. Also the hole was punched not drilled. My 65 is a smaller dia. than my 66. The hole in my 66 is just under 5/8 Tom
Hi Rodney,
Do you have the grommet for the choke cable hole?  Brant at Virginia Classic Mustang sells, but it is also the same grommet used for the antenna penetration from the fender area to the interior, if you want to find an original.
Best of luck
KR500
Tom, Thanks. Cory, Yes I have a VCM grommet. Going by the grommet I would estimate the size between 13/16" and 7/8". Another member has PMed me with a 7/8" size found on their 65. I did a 13/16" test hole on a piece of scrap and the grommet fit but it was tight. I measured the antenna hole at the body side panel and it measures .765". It would be a real struggle at best to get this grommet to go in to that hole. Any other input still welcome as I will wait a day or two before I go for it. Thank you all.
Rodney
Just measured a '66 carryover I have, ~0.768"
The holes were made with a hole saw that has a drill bit in the center.  Have found the sawn out plugs in floors of cars.  I don't think Ford ever punched out holes like this made after the unibody was assembled.
Quote from: KR500 on February 14, 2024, 10:16:02 AM
Rodney
I have a couple original grommets around, I seem to remember they were a little smaller than reproductions, but maybe it was due to rubber shrinking over time.  Will try to find them and measure.
Just checked an NOS grommet, slot diameter ~0.795"
KR500
Quote from: s2ms on February 14, 2024, 02:14:55 PM
That is pretty much the same size as the VCM repo measures.
Thank You
