R-model Shock Spacers
Started by 66TotalPerf, February 06, 2019, 12:21:44 PM
Quote from: gt350hr on February 15, 2019, 10:23:50 AM
   Doug,
     The spacer does NOTHING except keep the shock from bottoming out ( possible valve or seal damage) on a lowered front end.
Understood but my question remains. The 65 GT350 has the lowered upper a's and Koni shocks. Is that combination the criteria necessary to raise the shock to protect it from bottoming out?
I'm not arguing. I'm just curious. I never heard of this before this posting.
Is this something that only racing showed an overlooked need for?
OldGuy
Quote from: gt350hr on February 06, 2019, 12:48:00 PM
   Some were/are concerned about the shock "bottoming out and damaging the valving due to the upper control arm lowering of 1". Too much additional spacer runs the shock into the hood so less than 1" is often used. Bud Moore felt the whole bracket should be raised for improved strength and made aluminum plates to go under the shock bracket itself.
I'm curious as to why SA installed the "special" upper shock attaching bolts (with the thinned-out heads) if there is adequate spacing to allow for "riser" plates to be installed. I was under the impression that it was for hood clearance. Any thoughts?
Frank
66TotalPerf
#17
Quote from: OldGuy on February 15, 2019, 12:12:42 PM
Frank
The Koni-specific bolts weren't for hood clearance, they were used because the "fork" on the upper attachment point of the Koni shocks had less contact surface than the Ford shocks they replaced. The later 66 GT350s with the Ford (Gabriel) shocks did not receive these special bolts, only 65 and pre 6S900? cars did. Photos from VCM.
-Brent
'66 GT350 Tribute, '66 F100 4x4
Quote from: shelbydoug on February 15, 2019, 11:09:27 AM
   Doug,
        Doug ,
             We're good . Sometimes I do caps to highlight important things , not yell at you!   Though "I" never experienced it ( being a drag racer ) many "corner benders" added spacers to keep from damaging the shocks on lowered road race cars.
Quote from: BrentW on February 15, 2019, 12:32:11 PM
Frank
   +1 the attaching bolts were below the "eyelet" of the shock , regardless of make of shock.
Frank
As others have said the Fork on the head of a Koni shock is wider then a Ford shock. If you used a Factory Mustang front shock bolt on a Koni shock you will see very little bolt head contact with the sides of the Koni fork. The Special Shelby wide head bolts are not for hood clearance but they do offer hood protection. I could imagine a improper Ford bolt being used on a Koni shock and under harsh conditions the bolt would be forced through the wider fork allowing the head of the shock to slam up against the bottom side of the fiberglass hood on the next bump. I have seen and heard of that happening on some track cars although I can't confirm what hardware was used or the cause.
I think also the spacers keep the lower control arm from dropping too far and allowing the coil spring from coming unseated from the spring perch. More of a issue with lowering springs that have been cut.
Quote from: gt350hr on February 15, 2019, 05:10:13 PM
   Doug,
        Doug ,
Never thought that you were yelling at me at all. I was just wondering if these spacers are even necessary unless as Bob suggests, to keep cut springs from popping out?
I am using cut springs but found the car way too low in the front with them and it necessary to shim them up. I'd have to look at what is going on in there in my case to assess the need in my application?
I can see with the cut springs why Moore used a skid plate built into the oil pan. The car is so low, the pan could use caster wheels on it. A skid pad would be the next best thing?
I have the Canton pan which tucks in behind the front anti-sway bar.
A lot of what I've seen Bud Moore do seems almost like it was to just be different from what Shelby's team did?
Not that he should have been but he was always hush lipped to me as in contrast to the Woods brothers who were very friendly and sharing.
I know that the Daytonna Coupes got tricky and lowered the engine in the chassis 1". They even used a special oil pan to accommodate that engine lowering.  I never saw that detail on the R models but wouldn't be shocked if the team cars did that. Do you know anything about that?
