1967 Shelby Orig Hood, Nose, Trunk Lid, Rollbar, Grille and Taillight Boxes
Started by Andrew@MagMustangs, August 19, 2020, 04:11:13 PM
Andrew@MagMustangs
1967 Shelby GT350 and GT500. Original All Fiberglass Hood(metal latch support), 1-Piece Front Nose Section, All Fiberglass Trunk Lid, 4-Point Roll Bar(No Retractors), Outboard Upper Grille(Not slanted), and Tapered Tail Light Boxes. All for $20,000
No shipping. This is a deal you need to show up in person for and take them home with you, even if it is a cross-country trip.
These are All Original Parts from the same car. Not sure of the car number. The 'story' is that it went to an Asian Island Nation and was rusted out so the parts were salvaged from it. But then the car possibly came back to the states and might have been restored.  All of these parts are correct for Later cars with differences that bring the range into, I believe, the last few hundred cars built.
The Hood, Trunk Lid and Nose have all had heavy glass work done previously(looks like the work of one 'artist') and again need repairs. There are some chips and cracks here and there and they all have probably 4-5 coats of different colored paint.
The rollbar tubes were cut at the bottom like most are when removed. Doesn't have the lower brackets but it otherwise looks excellent in my opinion. No heavy rust at all. The metal just discolored from age really. The padding looks excellent with just a small spot of discoloration at bottom LH and there are just a couple minor cuts on the very top which won't even be seen installed. The padding at the top of each upper mount ear is also a little rough. In my opinion the padding looks excellent for it's age and compared to a lot of them.
The outboard grille is great. No cracks or splits. There are a few minor dings and waves but will be very easy to straighten out.
The tail light boxes have been previously blasted and there are a few rust spots. They are very straight.
These all need work, but all the original details are there on these parts. If you have a bare Shelby that needs everything then this could be great for you. Finding all these parts in one place is basically impossible.
You can contact us through PM or at 360.573.6056 or magmustangs@gmail.com. Serious inquires or comments only please.
