Vacuum fitting GT350 aluminum intake
Started by Horsman, February 27, 2020, 09:07:55 AM
Horsman
When I purchased my car the intake was missing. Wondering how the tilt away column received its vacuum source at the back of the intake manifold, is there a specific combo fitting that provided vacuum for the brake booster and tilt away?
Thanks in advance.
Don't think '67 Shelby's had the tilt-wheel, the'68's did - Others will know better...
Horsman
Quote from: JD on February 27, 2020, 09:12:13 AM
Mine is a 67 K-code I am outfitting the engine like a Shelby GT350.
Quote from: Horsman on February 27, 2020, 09:20:31 AM
Oh, sorry - hopefully someone can help steer you in the right direction...
Quote from: Horsman on February 27, 2020, 09:07:55 AM
Thanks in advance.
Do you have a automatic or 4sp. What about power brakes . Those things would impact what you could use on a Cobra Intake.
Horsman
Quote from: Bob Gaines on February 27, 2020, 02:52:22 PM
Thanks in advance.
Thanks Bob. My car is a four speed with power disc brakes.
Quote from: Horsman on February 27, 2020, 06:24:51 PM
Thanks in advance.
Here is a 67 Mustang version for a auto car. It would thread into the second vacuum port on the cobra intake .The first one of course of for the pcv. The automatic version has the taper for the modulator valve but a manual with a booster would not taper. You can of course cut the taper portion off or find one that  is not tapered. The 1/8 vacuum nipple could be used for the tilt . You do know that you will need a vacuum reservoir for the tilt also. It is available on the shelf if you can't find one.
Horsman
Quote from: Bob Gaines on February 27, 2020, 07:00:49 PM
Thanks in advance.
Thanks Bob, I will try to hunt that fitting down...unless someone here has one they could part with. My car was equipped with the wood style wheel and tilt away from the factory, the canister is mounted close to the firewall on the right side of the car, looks like a short coffee can.
