Bullitt type Ford wire connectors
Started by shelby001, February 22, 2020, 01:04:18 PM
shelby001
Anyone know of a supplier that sells bullet type wire connectors that fit the Ford connectors (male & female )??
Could you be more specific on what you are wanting to do with them because I am unsure which ones you are looking for?
pmustang
I bought perfect bullet ones a few years back and use them all the time. The name of the supplier was Del City
shelby001
Quote from: pmustang on February 23, 2020, 04:01:26 AM
Its for a 66 Rally- Pac wires,  they were cut off so need mostly male ends & one female . I found some at local parts source but they are larger on the pin side & do not mate with under dash plug in`s
Quote from: shelby001 on February 23, 2020, 12:51:59 PM
IMO it would be best from a looks stand point to source the connectors from a donor Ford under dash harness. It doesn't even have to be a Mustang harness. I would try to stay within 66-68 time frame however.  The typical after market bullet connectors will not typically look close like ones from a Ford harness will. If authenticity doesn't matter then the aftermarket will be the easiest choice.
Im pretty sure there is a rally pack wiring harness premade with the correct connectors aroung $25
Don Johnston
I believe I got my replacement harness with correct connectors and wires from Virginia  Classic Mustang.  They may have the correct bullet connectors for the Rally Pac unit.
Just nuts.
shelby001
Quote from: Coralsnake on February 23, 2020, 01:16:13 PM
Ya I think that is a Scott Drake item for the new Rally - Pac which are wired different than the OEM . I will check it out . I like bobs idea of sourcing an old wiring harness.
Thanks for everyone`s help .
Sorry, I am not speaking of the Drake item. I do not recommend Drake products for a Shelby.
I can get you a new direct replacement harness
shelby001
A new replacement harness for the Rally-Pac?
Yes, made by Alloy Metal Products in the USA
The Going Thing
If you don't want to pull it off and a part I do have one male and female crimp that will work together or with ford connectors. I'd be glad to send it to you at no charge.
This is a test: "California"
Welcome back  :D
