CSX 3015 super snake on craigslist ????
Started by GTBULLITT, March 15, 2018, 09:21:50 PM
mickmate
Thanks Doug the big book says the blower cars had a wide brake pedal with Cobra Automatic on them. I have seen an auto 289 but it had been switched to a manual when I saw it. You might be thinking of the other few automatics they made?
We need to go to Ned Scudder for an answer to this one? Hey Ned?
cobrajeff
Factory automatic Cobra brake pedals....
This is Shelby's SuperSnake, CSX3015
and this one is Shelby's 289, CSX2589
Jeff
migaffney
Pictures of brake pedal on CSX3141 that I have owned since 1972.  This is one of the 2 regular 427s out of four total automatics, the other 2 were supercharged.  MG
Cobra Ned
Jeff's photos have already answered the question. 3141 does have a different brake pedal than that in the Supersnake.
mickmate
The fabulous depth and breadth of knowledge is drilled down into. I see the single AC pedal has a lot more offset to help center it in the now cavernous foot box. Thanks Jeff. Mike it looks like they are using both pedal arms for the double wide pedal pad. Does it have the under and over dual master cylinders and is it just using the clutch arm to steady the brake pedal or is it using a master on both arms for a separate side by side dual master?
rodneym
mickmate,
The big book also said it had a Mickey Thompson intake.  :-\
Is that bead on the trans tunnel a "cheat"? Carpeting the right side is a beotch!
rodneym
mickmate
Originally yes, they must have got sick of mucking about with the extended distributor drive when they replaced it with the Edelbrock.
rodneym
So CSX3015 did have a MT intake originally?
Any evidence of that?
rodneym
mickmate
The big book. Any opinions on whether the edged rug is correct? I have seen it with and without.
