windshield tape
Started by acman63, March 26, 2018, 01:00:50 PM
acman63
My source for the rolls of what they called Butyl caulk tap  has changed,  doesny one have a source for the correct thickness  believe its 5/16  in.  the gooey black stuff
SAAC Concours Chairman
acman63
Thanks Paul>  looks to be the same
KR Convertible
No problem.  Glad I could help you for a change!
Dan353
C.R. Larurence is a glass supply company we used to order all our automotive glass supplies from them when I worked as a glazer
Dan
http://www.crlaurence.com/crlapps/showline/offerpage.aspx?ProductID=12454&GroupID=19979&History=30587:19747:19756:19747:19758:19954&ModelID=19979&pom=0
Sfm6sxxx
Quote from: Dan353 on March 26, 2018, 06:39:32 PM
Dan
+1
If you are using a reproduction windshield, you may want to consider using the 3/8" butyl tape because the glass is thinner and it can cause the trim to sit lower than original.
6S1114
Quote from: Sfm6sxxx on March 26, 2018, 07:14:24 PM
That's what we've had to do
