65 66 GT350r Long / Extra range Fuel / Gas tank Wanted
Started by Bossbob123, May 31, 2020, 09:05:55 AM
Bossbob123
Hi Guys, Im looking to purchase or have fabricated a double gas tank with the internal baffles for a 65 66 GT350R.  Any help will be appreciated.
Please contact thru private messaging.
Thank You
Bob B
Shelby_r_b
Hi Bob,
Try Jim Cowles at Shelby Parts and Restoration.  920-434-3645.
Nothing beats a classic!
gt350bp
Might want to consider a custom fuel cell bladder to fit the tank?
Don
gt350bp
Bossbob123
Guys, Thank You For the info.  It is appreciated
If someone does see this and has a tank for sale, let me know.
Bob B
werthie
hi guys . . .   6S929 came to me with a fuel cell, and i'd like to replace it with a stock tank . . .  thoughts about whether to go with the original 16 gallon or the '67 and later 22 gallon?  i like the idea of more fuel capacity, but then there's added weight and the bulge in the trunk.
please advise . . . .
alan in LA
Quote from: werthie on May 31, 2020, 08:42:18 PM
alan in LA
Actually 65-68 are the same . Unless you are planning a lot of long distance driving I don't think there is a good arguement for the larger capacity non original tank . I did it on mine back in the early 70's but I was driving it daily and driving on long distance trips occasionaly . It doesn't make sense to me now. It is your car so do as you want . You can always switch it back if you are dead set on doing it. I think you regret doing it in the end . You will have to decide if it makes sense to you.
The 22 gallon is a 1970 Model year part. 67 is a 16 gallon.
I put the 22 in both my 67 and 68 cars. At one time it helped on long trips BUT on a full tank you have more of a tendency to spill out of the filler on a steep incline.
The extra 6 gallons gives you 100 to 120 more mile range. The added weight is actually a help to the handling of the car since the Mustang tends to be front end biased.
I think on the race cars it was actually a way of cheating. I forget now how the tech people checked the weight of the car? At the time, I don't think they looked at the fuel in the tank?
The race tank is two 16's welded together for 32 gallons. Today there is no point to that since you can run 20 minutes on the track with about 5 gallons.
Those were useful for events like Daytonna, Sebring or Lemans.
So unless you just like the look of the race tank and/or you are going to store fuel in it, there is no sense to it at all.
I think the minimum race weight was 2800 pounds? Some cars needed to have ballast added to them. You can get a Mustang down to about 2700 pounds so playing with fuel in the tank might give you an "unfair advantage" if you work it right.
