Factory Rear Sway Bar Kit
Started by CSX4781, August 02, 2020, 05:39:44 PM
papa scoops
my 66 also had the dozx boss 302 sway bar kit installed in 1970. it was for the boss 302 originally, is it any good? can't say, i removed it a few years ago. threw it "in the field" {was loose nd rattled} phred
Quote from: papa scoops on August 04, 2020, 12:05:40 PM
LMAO! That's funny!
What's not so funny is how much good stuff is actually buried in Phred's field...
NC TRACKRAT
In addition to the diameter of the bar, adjusting the position of the drop-links with respect to the end of the bar will cause the bar to be stiffer or weaker.  A common mistake is to forget to check for no pre-load on the drop-links.  They should be set with the suspension loaded and both drop-links should be neutral.  This is true for both front and rear bars.
5S071, 6S1467
Quote from: s2ms on August 04, 2020, 03:31:54 PM
Just stuff, no bodies right?
