Hood Latch
Started by greekz, August 27, 2020, 02:03:37 PM
greekz
I believe the hood latch is a phosphate and oil finish.  Has anyone had theirs chemically finished?  If so, was the spring damaged from the process?  Looking to finish mine with the correct finish.
Greek
SFM 6S1134  '67 GT-350 #2339
I remove the springs, but it's ok to phosphate them also.  Temperature of phosphate solution should max out around 180F.
If you're going to have them done by a business I would remove them and let them know that you don't want high heat used on them. The process can cause embrittlement in springs. Just something to be mindful of. Hood hinges springs also
If doing them at home like allot of us do then you can control the heat as Charles wrote above
greekz
Thanks for the tips.
I have already removed the small springs.  Are they phosphate and oil?
Any tips on how to remove the large spring.
To the best of my knowledge they were originally phosphate, like the hood hinge springs.  It was either that or natural darkened spring steel finish, which would look very similar to phosphate.
I prefer manganese phosphate over zinc phosphate.  Manganese matches closest to original fasteners and parts I've observed over the years.
greekz
Quote from: CharlesTurner on August 28, 2020, 09:31:33 PM
Thank you.
