Hard chrome - convertible windshield molding header trim
Started by nvr-enuf, September 12, 2020, 11:42:06 AM
nvr-enuf
My 68 convert header piece needs to be redone and I believe it is "hard chrome" not shiny chrome
Does any forum members have a contact for redoing this piece ?
Pls reply or pm me
Scott
Quote from: nvr-enuf on September 12, 2020, 11:42:06 AM
Pls reply or pm me
Scott
I have not heard referred to as hard chrome but regardless Tim Lea told me he had someone at one time that did some.
I had a company(now defunct) re-chrome my 69 header and visor pieces and it was really hard to get the satin look of it. They told me they had to trying it multiple times to get the look. Gary
It's called satin chrome. The original process was done by shooting high pressure water onto the chrome shortly after the move from the vat. Nobody has that exact technique anymore except in industrial applications but there are companies that can simulate a look
nvr-enuf
Looking thru a vendor books I did find a source that offers the satin chrome
Thanks for the responses
Quote from: nvr-enuf on September 12, 2020, 08:43:50 PM
Keep us posted with what you find out and or results.
vtgt500
I have minimal experience with automotive decorative chrome, but design and build custom machine tools with industrial chrome.  Hard chrome is typically applied to worn or under size surfaces to restore size.  Always need to be ground back to a specific, finish size.  Seldom practical to apply over .015 inch.
We use satin chrome on handles, levers and knobs to prevent corrosion and improve appearance.  Same as seen on Starrett micrometer frames and machinist's pocket scales.  Essentially the same electrolytic processes as hard chrome.  But surfaces are first vapor blasted with a micro abrasive to achieve a uniform, mat finish.  Chrome application is no more than .0001-.0002 inch.  Has become increasingly expensive.
