jacking points w 4 post lift?
Started by EdwardGT350, September 08, 2020, 01:39:11 PM
EdwardGT350
where is the best location to place the 4 post lift hockey pucks?
is the pinch weld strong enough?
tia
1966 GT350 6s1761
It's where they recommend jacking it up to change a tire. I'd worry about side loading them if lifting on all 4 points at once. Most people put the pads under the sub frames. It seems to work as the pads are big enough to spread the weight out and not damage them.
trotrof1
If you have underides, I use a block of wood straddling the front mount where it lays flat against the sub frame. I also wrap the wood with a shop towel to prevent damage to paint or coatings.
69mach351w
Quote from: EdwardGT350 on September 08, 2020, 01:39:11 PM
tia
I think you mean - place to put the 4 hockey pucks on a 2 post lift. A 4 post lift is designed for you to drive on ramps. Regardless I can't imagine a better example then the previous post reply #3.
EdwardGT350
bob, yes meant 2 post lift with the 4 arms. thanks
are the rear pucks placed on the forward leaf spring attachment area?
1966 GT350 6s1761
69mach351w
Quote from: EdwardGT350 on September 08, 2020, 07:53:43 PM
Yes.
