Upper Control Arm Shims
Started by hertz350, November 29, 2020, 09:05:23 AM
hertz350
My 66 Shelby had about 10 alignment shims per side used with the upper control arms. Did 66 Shelbys use more shims since they had the longer pitman and idler arms?
OldGuy
The shims used on the upper control arms are for adjusting caster/camber to achieve the proper wheel alignment. The shims have nothing to do with the steering linkage components.
Frank
trotrof1
You can always use a thicker shims to lower the shim count.
It's either in the shop manual or assembly manuals where a starting point thickness is provided with the shim sizes.
Note that the original shims are squared across the top.  Lots of incorrect round or ones with a tab.  Originals can usually be cleaned and zinc plated.
427hunter
Your car does not have the Shelby A arm drop correct?
Inigo Montoya
Jackie Brown
hertz350
Correct. My A arms are not lowered.
hertz350
Thanks for the replies and help.
