Mustang Day May 2018 France - Nimes Ledenon
Started by fm hipo gt 1966, June 06, 2018, 01:49:18 PM
fm hipo gt 1966
Quote from: texas swede on June 07, 2018, 06:21:17 PM
Something doesn't add up as the green 67 has a later rear valence panel.
Texas Swede
Yes, if it is #156 then it seems as though a few thing have been "changed" over the years, some noted in the registry.
The grill in the images does not look to be the angled/slanted - note the strip along the lower edge of the upper section.  If it is they cut it to locate the kill switch which would be a shame.  Four chrome trim rings on the headlights and as Texas Swede noted the rear valance is the later version, too late for #156.  It does seem to have early flat tail light panel.
I would think #156 would have the plates for the inboard grille hi-beams.
The Upper Scoop Lights were noted in the registry as having been removed at one time.  That might explain why the ones on the car look to be a different style and located back a bit more than originals.
Looks like the owner has a real running and enjoys it, must get a lot of attention if France!
Rich, have you figured out which car the '67 with the outboards yet?
Thanks all for posting.
Richstang
#32
Quote from: fm hipo gt 1966 on June 10, 2018, 06:20:00 AM
This one was there as well :
Hey!!! Claude drove your '66 Coupe...Nice to see him behind the wheel of a Hi-Po Mustang again even if it's not a R model.
This '68 looks nice. The front license plate nearly blocks the entire lower grille area, good thing it's only a GT350.
1967 Shelby Research Group
www.1967ShelbyResearch.com
Richstang
Quote from: JD on June 10, 2018, 09:54:08 AM
Texas Swede
Yes, if it is #156 then it seems as thought a few thing have been "changed" over the years, some noted in the registry.
The grill in the images does not look to be the angled/slanted - note the strip along the lower edge of the upper section.  If it is they cut it to locate the kill switch which would be a shame.  Four chrome trim rings on the headlights and as Texas Swede noted the rear valance is the later version too late for #156.  It does seem to have early flat tail light panel.
JD,
Lot of good points. Check out the YouTube video in reply #11. It shows the car does indeed have the plates for the grille light mounting. It also does appear to be a vertical upper grille with that lower strip. Good catch. I'll update our posted list.
The Acapulco blue car is #2607. It was also at the 2010 Mans Classic up for auction.
