Something Different - Sunbeam Alpine with 429 engine on CL
Started by JWH, February 09, 2021, 02:38:36 PM
Complete with pistol  grip shifter!!!you don't see that in a Ford everyday(or ever)..... :o
Holy smokes! If they ever bring back 'trollies' they can hire that guy to cut the grooves for the tracks with his burnouts?
I am wondering if it will not overheat in anything over 70 degrees. ;)
Quote from: Bob Gaines on February 09, 2021, 03:33:44 PM
Probably no worse then a 67 GT500?  ;D
 Bet the weight distribution makes it "interesting"in turns. :o
BGlover67
It's like sitting on a big block.  The 'transmission tunnel' is more like the 'engine tunnel'.   :o
Brian R. Glover
Quote from: shelbydoug on February 09, 2021, 03:42:57 PM
Keeping a 67 GT 500 cool would be a piece of cake by comparison IMO. A mildly warmed over 289 in a Tiger could have cooling issues I can't imagine what lengths you would have to go through to cool even a mild 429 in that small closed engine space . It is not like you could fit a much higher capacity radiator then what is available for a high performance 289 Tiger in it.
Side-Oilers
Quote from: Bob Gaines on February 09, 2021, 03:49:24 PM
You could remove the hood.  Helps cool things down, and shows the world what you're packin'.
Current:
Previous:
1970 Ranchero GT 429
1969 LTD Country Squire 429
1963 T-Bird Sport Roadster
1957 T-Bird E-model
69mach351w
Seems the back brakes need to be adjusted.  Look how high the e-brake handle is up. :o
There are people who absolutely no hot restarting problems with 67 500's others it's a nighmare. Probably most are somewhere in between.
I don't think the oxigenated gas helps. I think it tends to flash? Could be the big variable depending on where you are in the country since the blends probably vary just enough?
A double thick radiator MIGHT help but it ain't gonna' be cheap. Even so, an 'interesting" concept.
Quote from: shelbydoug on February 09, 2021, 07:56:51 PM
As I mentioned before Tigers have cooling problems typically when the engines get modified.I have had my share of dealing with the tiger cooling problem. The Tiger aftermarket has come up with various extra thick,double thick radiators for use with modified engines. The problem is there is only so much space in that body to fir expanded radiator size. I think the aftermarket has maxed out the off the shelf radiator size for what will fit in the space available for that body. I would venture to say that cooling is one of the issues that the seller was talking about needing finishing while sorting out the car. I may be wrong but think it is a good guess given what I see.
Starts, runs, stops and drives. Needs some fine tuning
I notice he doesn't say it will turn.
