Tranny swap
Started by 68krrrr, April 16, 2022, 10:22:05 PM
68krrrr
And no I'm not confused about which bathroom to use lol ,but seriously looking for opinions on  an automatic to 4 speed swap .Who's done it ? any advantages or disadvantages and how involved of a project is it , like how hard is to get the correct parts for the swap (& what exactly should I be searching for) . My engine is already out  & being rebuilt ,so this is the time to do it if I was going to. Being an automatic you already take a hit in value ,what I'm wondering is does a 4 speed swap give you an even bigger hit in value or would it keep it even ,with the value of an automatic possibly ,or is it as drastic as a color change.
At the end of the day the cars for me & I love it either way ,it took me years to find an inboard, Nightmist blue/parchment color combo & I ended up settling for an auto ,because a 4 speed in that color, never came up for sale ,in my probable five year search.I do plan on keeping it & enjoying it for a long time.
Current
1967 GT500 #1724
Nightmist Blue /Parchment
2005 Ford Gt Midnight blue
1934 Ford Chopped & channeled
Previously owned
1968 GT/CS
"Fly low & avoid the radar"
Thanks Adam
Kent
Hello, you need a bellhousing, inspection plate, block plate, clutch, clutch fork, throwout bearing, clutch equalizer and mounting stuff for it, flywheel with bolts, starter, pedal assembly, shifter assembly, shifter plate, linkage, insulator, 4 speed tranny, tranny mount is also different, if you use an 31 spline toploader you can use the yoke from the C6 if you have an gt500. Driveshaft is different on a GT500. For the value I would say its the same as long you use Fomoco stuff.
427heaven
I thought furshure this was going to be a BRUCE to Kaitlin thing! :-[
Lfino
I converted my 67 500. No issues. Everything bolts right up. Bellhousing with the Hump is needed. Clutch pedal assembly of course. Different speedo cable. Transmission mount with 390 stamp. And drive shaft to fit. Easy.
68krrrr
Current
1967 GT500 #1724
Previously owned
1968 GT/CS
Thanks Adam
corbins
And it would be wise to rebuild the pedal support you get. Use the roller bearings, they keep it nice and smooth .
430dragpack
When you say "getting the correct parts",  well the correct transmission with correct big block shifter and clutch fork for your 67 GT500 isn't easy and all the other parts needed will add up to a pretty substantial cost.  Can you install all of this yourself?  Because if you can't, it's pretty labor intensive on an already completed car, especially the clutch support/pedals.  Of course you can get parts that will work for less that aren't "correct" but.??.  Not trying to deter you, just saying it would be expensive if trying to go "correct".  It's your car...have fun!
brandosaac
If youre still considering this swap,
I have a few big in/out toploaders , restored clutch pedal assembly , flywheel, possibly a BB shifter assy with kick back plate, and  some of the clutch linkage as well.
send me a PM if interested
