65 gt 350 side stripe details
Started by DRGT350, March 31, 2021, 06:51:57 PM
DRGT350
we are nearing the point of painting the side stripes on 5s296 -
From the attached picture is looks like the stripe was masked off where the quarter panel line  meets the door striker panel and proceeds along that line on the top of the rocker panel - is this correct?
For the front of the door  - is there a detail that anyone can share? was there overspray in the area between the front of the door and back of the fender?  or was this area masked off as well?
Does the stripe have a return on the door and on the fender?
Thanks in advance for the help !
About half of that amount would be typical, although it was not an exact measurement from car to car.
Here are some pictures. Not all pretty and very focused but you get the idea - hopefully
Front fender lip
Top of rocker/sill area at the A pillar
Takes a second to figure out this is the drivers rear corner of the door opening - rocker/sill to left - quarter panel to the right
Rear wheel opening, lip with overspray of the blue onto and over the white body color and under that the sound deadener in the wheel well
Overspray onto the white sound deadener and a small section of the frame rail behind it on this example
Blow out from tape not applied or push down in corners as well as overspray where they didn't tape or mask
Hope these help
DRGT350
Thank you Charles and Jeff- very helpful- !
DRGT350
DRGT350
can anyone suggest a source for the single stage guardsman blue paint?
thanks,
dave
