Door latch question
Started by hertz350, April 16, 2021, 04:13:59 PM
hertz350
I am using NOS door latches on a '66 Hertz car. These new in-the-Ford boxes have a Cosmoline coating.
Was this coating on the assembly line latches. If so, did it leave Shelby that way?
Thanks.
Quote from: hertz350 on April 16, 2021, 04:13:59 PM
Thanks.
You don't see signs of dark cosmoline on the outside of assemblyline latches . The service parts got a heavy dose all over however . If protectrant was used on the assemblyline latches it was minimal and not noticeable when you opened the door . FYI the cosmoline will turn dark with age. I would suggest taking it off with some lacquer thinner if you want it to look like assemblyline.
I have seen some pretty dirty/nasty original door latches, so I suspect at least some of them had a cosmoline coating, to some degree.  There is almost always thick cosmoline on the backside of original latches.
Quote from: CharlesTurner on April 16, 2021, 09:03:04 PM
I agree but my point is that you typically don't find the heavy dark cosmoline on the portion that you see when the door is open so at the very least it was minimally used or wiped off on that portion seen when the door is opened.
hertz350
