Fog lights harness routing
Started by corbins, June 07, 2021, 03:17:17 PM
corbins
Hey, can someone post a couple of pics of the routing for the fog light harness from firewall to lights?  I'm waiting for the electrical manual and supplement to come in and just wanted to see how this thing was run.
Thanks for any help !!
Steve
Quote from: corbins on June 07, 2021, 03:17:17 PM
Steve
Just so as to get you prepared so that you are not surprised when you receive your manuals the electrical manual does not show any Shelby unique wiring. The 69 Shelby shop manual supplement only shows a basic schematic of the harness and not how it is laid out in the car.
corbins
Oh sh**t !  Guess I'll need to find a good car to look at ....  thanks man !
Soooo....anyone in the Richmond, Fredericksburg Va area with a 69 500 ?
69 GT350 Vert
I think routing is the same regardless of 350, 500, vert, or fb.  I believe it passes through dedicated hole in firewall,  strapped to right shock tower, and likely right export brace.  Passes through alternator harness plastic harness retainer.  Ground for fog light harness goes under voltage regulator mount bolt.  Harness passes through hole in radiator support under battery, and is held with headlight harness plastic clips along bottom of radiator support.
corbins
Thanks 69 Vert !  good help ! you wouldn't have a close up of that fire wall hole would you ?
69 GT350 Vert
It is the hole closest to the heater hoses in this photo.  The rubber grommet of fog light harness isn't pressed into the hole in firewall in this photo.
