1966 GT350 Brake Light Switch Part #?
Started by JWH, June 10, 2021, 09:56:14 PM
JWH
What is the correct part # for the brake light switch on a 1966 GT350?
For future searches, is the switch the same part # on both 1965 and 1966 GT350s?
Jeff
Either of these are correct for both 65 and 66...
Ford C5AZ-13480-D (Autolite SW-521)
Ford C9ZZ-13480-A (Motorcraft SW-863)
I believe C7ZZ-13480-B is also correct.
JWH
Thank you for posting the part #s. This puts me on the right track.
JWH
I called Virginia Mustang and ordered the brake light switch and they sent me a Scott Drake switch with part #C9ZZ-13480-A, which is one that S2MS listed above. The packaging references 65-66/67-70 Manual Brake Switch. It took some patience to get it installed but the brake lights are working perfectly now.
       I highly recommend taking 5 minutes and removing the front seat to make climbing under the dash easier and WAY more comfortable.
Jeff
