67 GT350 oil cap saying autolite with emissions tube( found)
Started by 68cobra427, July 08, 2021, 11:26:22 AM
68cobra427
Chrome or painted as long as not dented and scratched up.
Troy
Seems as though you are asking...hope this helps  (if the up-load folder is accepting files)
No Luck:
An Error Has Occurred!
The upload folder is full. Please try a smaller file and/or contact an administrator.
Back
68cobra427
Ya upload is not working.
Email direct please.
hmc@eotnet.net
Troy
Quote from: 68cobra427 on July 08, 2021, 11:54:35 AM
hmc@eotnet.net
Troy
Done -
Sent the summary of this topic from the 15 page article on '67 Shelby Running Changes that was in the Fall of 2013 Shelby American.
The Italic type means this was a Ford Running Change and therefore Shelby got what was made at San Jose and delivered to Shelby American.
Will try to remember to post here when the upload folder issue is resolved ;-)
Here is the text from the article:
OIL FILTER & BREATHER CAPS
There are numerous variations on this but here are the most common, to the best of the evidence we have so far. The GT350 valve cover open emissions (non-thermactor), early style oil filler was chrome with FoMoCo in script in the oval. Later versions were chrome and stamped Autolite. The GT350 valve cover thermactor equipped oil filler cap was the closed emissions style, as seen on '65-'66 GT350s, typically chrome but with FoMoCo in script block letters inside the oval rectangle. The GT500 open emissions (non-thermactor) valve cover oil filler was black or chrome, marked FoMoCo in "block" letters inside the rectangle. Later on in production, they were chrome or black and marked Autolite. The GT500 valve cover thermactor equipped engine used a closed style (short in height when compared to the other style) cap and is referred to as "Cookie Cutter" style because of the edges of the cap; they are chrome and marked Autolite. The GT500 intake oil filler tube, cap is a small diameter push-on style (like the GT350 open style valve cover cap), chrome or black, with FoMoCo in script in the oval, or later Autolite. The GT500 thermactor intake oil filler cap is chrome or black with FoMoCo in script in the oval or later on, Autolite. The other much less typical early cap is black or chrome open style, like the '65-'66 GT350 valve cover oil cap.
(From The Shelby American, Fall 2013, 1967 Shelbys - A Year of Changes, Variations and Transformation)
(edit as suggested below)
Quote from: JD on July 08, 2021, 12:02:13 PM
hmc@eotnet.net
Troy
Done -
There are numerous variations on this but here are the most common, to the best of the evidence we have so far. The GT350 valve cover open emissions (non-thermactor), early style oil filler was chrome with FoMoCo in script in the oval. Later versions were chrome and stamped Autolite. The GT350 valve cover thermactor equipped oil filler cap was the closed style, as seen on '65-'66 GT350s, typically chrome with FoMoCo in script inside the oval. The GT500 open emissions (non-thermactor) valve cover oil filler was black or chrome, marked FoMoCo in "block" letters inside the rectangle. Later on in production, they were chrome or black and marked Autolite. The GT500 valve cover thermactor equipped engine used a closed style (short in height when compared to the other style) cap and is referred to as "Cookie Cutter" style because of the edges of the cap; they are chrome and marked Autolite. The GT500 intake oil filler tube, cap is a small diameter push-on style (like the GT350 open style valve cover cap), chrome or black, with FoMoCo in script in the oval, or later Autolite. The GT500 thermactor intake oil filler cap is chrome or black with FoMoCo in script in the oval or later on, Autolite. The other much less typical early cap is black or chrome open style, like the '65-'66 GT350 valve cover oil cap.
The highlighted explanation needs to be updated to - "The GT350 valve cover thermactor equipped oil filler cap was the closed emission style, as seen on '65-'66 GT350s, typically chrome but with FoMoCo in block letters inside the rectangle." With that said the reason is that most thermactor equipped 67 GT350's were later production cars and the typical cap trademark had evolved to the FOMOCO in the rectangle
430dragpack
Quote from: Bob Gaines on July 08, 2021, 02:17:45 PM
hmc@eotnet.net
Troy
Done -
Also, what about the un-marked "cookie cutter caps" usage?  If we are making amendments.  Also the redundancy of the GT500 intake oil fill cap being the same for thermactor and non thermactor, according to the two sentences about them.
Quote from: 430dragpack on July 08, 2021, 04:25:33 PM
hmc@eotnet.net
Troy
Done -
I am ok with the redundancy because otherwise there will always be that person who wants to confirm if it is not in writing. Don't ask me why the open emission cap was used with thermactor system oil fill tube. As spec Ed says "that's just the way it is".  The unmarked cookie cutter cap is much more typical compared to the Autolite version. I am skeptical that the Autolite version was used at all originally on 67 GT500 but not sure so I always give the benefit of the doubt when the issue comes up in concours judging.
Adjusted the reply #3 above to reflect the suggested edit/change.
Also, a couple images of some of the variations...
