67 GT350 Power Steering Hoses
Started by Hockeylife, September 09, 2021, 04:02:36 PM
Hockeylife
Anybody have any experience with these hoses, good, bad indifferent? Who makes, are they concours correct?
I asked same, received no answer via auction.
https://www.ebay.com/itm/133787626712?hash=item1f265d2cd8:g:ddsAAOSwEUdeTs5H
Quote from: Hockeylife on September 09, 2021, 04:02:36 PM
I don't have experience with the seller but the hoses picture are made by Blue Dot  https://bluedotspecialties.com/ . The blue dot ps hoses are the best reproduction currently on the market. They are extremely close in appearance to OEM.
JWH
I have installed Blue Dot hoses on two cars now and the fit is excellent and these guys are above and beyond excellent to work with. If the correct look is what you are after, Blue Dot is a good way to go. If I recall, the set of hoses on eBay are marked up quite a bit, you should save some $$$ ordering direct from Blue Dot.
PS - take pictures and mark the small hoses with a piece of tape labeling the orientation from control valve to assist cylinder before removing. You don't want to reverse the ports when you install the new hoses or the steering wheel will kick like a pissed-off mule.
Hockeylife
