Softest trunk weather-strip?
Started by CharlesTurner, August 20, 2021, 10:59:34 AM
Anyone found a replacement trunk weather-strip for a convertible that isn't hard as a brick?  Had the trunk lid fitting perfect, but now had to adjust the latch up to even be able to close after gluing on new weather-strip.
The carpenter one is the best but the trick is how you glue it. At the 4 radius points leave rubber 1/4" away from fiberglass. Smith even had an issue with these as we've seen original cars with body side lip beat down with rubber mallet
Thanks.  I have the carpenter one installed, will see if I can pull it back and re-glue.
corbins
Got mine from Va Mustang.... had to take the "hard" off... couldnt even shut the decklid :) Softer one did MUCH better
8T03S1425
Glad you got it fixed.
After I retrieved my car from the restorer I used, I had to return it for, among other issues, the rear deck not closing to lock unless I applied considerable force and multiple attempts. When I got it back, it worked much better. I asked about the fix and the guy told me he bought the wrong weather seal. He said he bought a fastback weather seal and it had the wrong profile.
Steve
I owned 6S2295 in 1973 & '74.
