1968 Shelby tail light panel color
Started by 427heaven, November 14, 2021, 04:56:47 PM
427heaven
What is the correct 1968 Shelby Tail light color paint code for that Silver Grey color?
KR500
 Ford's Argent Silver is the color. I don't have the paint code handy at the moment.
Rodney
hurlbird
high gloss finish like the rest of the body?
427heaven
427heaven
While Im on the correct tail light panel color, what is the correct pop rivets in both size and color for same panel?
Quote from: 427heaven on November 15, 2021, 09:46:45 AM
Not pop rivets. Large head black stainless sheet metal screws. '67's use pop rivets. Not '68s.
427heaven
Thanks Doug thats what I needed to know...
Quote from: shelbydoug on November 15, 2021, 09:49:25 AM
To be a little more precise the screws installed at AO Smith were a medium to dark grey Phosphate and oil. A truss head lath screw from the hardware store is very similar however they typically come plated zinc silver so you would have to change the finish to be historically accurate. 5 minutes in some muratic acid from the same hardware store strips the finish off then wash in cold water before dunking the screws in some Quick black from Eastwood for about 20 seconds to get the desired finish. You would then dry and coat with your rust inhibitor o choice . I use T9 .
427heaven
WOW ...Thanks Bob, that is very specific, and I will try to get them accurate as explained. ;)
There were two different finishes used on these panel fasteners . They are the black oxide and bright zinc.
KR500
Quote from: Coralsnake on November 15, 2021, 11:39:38 AM
+1
427heaven
