289 Cobra parts wanted
Started by wcampbell, December 07, 2021, 02:31:20 PM
wcampbell
Looking for these parts:
- Smiths 0-160mph Speedometer gauge
- Smiths oil temperature gauge
- Carter 3623 fuel pump (May/June/July '63 dated)
- Girling type 12 rear brake calipers
- Lucas wiper arms/blades
- COBRA lettered 5 bolt scattershield
If you have any information on the parts listed for sale I'd greatly appreciate it and will make it worth your while!
Wayne
dwcampbell0@gmail.com
Recent topic on fuel pump...  https://www.saacforum.com/index.php?topic=17217.msg139020#msg139020
Let me know what the wiper arms/blades should be, I have a bunch of those.
Dan Case
Quote from: CharlesTurner on December 07, 2021, 03:11:05 PM
He is looking for:
Arm, Wiper Assembly
Lucas® 745101 (Shelby American S1CS-17529-A, Lucas® service part 745071)
Single mono leaf spring. Lying free on the bench, mount facing up, the length is 10-5/8" from center of mounting pocket to tip. The new old stock one I measured had an 11° bend down towards the cowl about 1-1/4" from the tip.
Blade, Wiper Assembly (includes wiping element) ("RAINBOW" trade name BUT NOT MARKED "TRICO")
Lucas® 738124 (Shelby American S1CS-17529-B)
Element, Wiping (a.k.a. insert, rubber refill)
Lucas® 737919 or 738736 (see more below)
A.C. Cars is known to have used two lengths. The one in 8-1/4" overall was the most common but they also used a 9" version. One unknown chassis number new car clearly had one 8-1/4" element (believed to be an "8" inch Lucas® 737919 "RUBBER REFILL" and one 9" element (believed to be Lucas® 738736 "RUBBER REFILL")
Dan Case
wcampbell
Thanks guys for helping sleuth these parts out. No response still from the CL list posting the 3623S....
Dan Case
Quote from: wcampbell on December 07, 2021, 05:14:45 PM
Any preference on the COBRA steel bell housing version? There were ones made in 1963, in 1964, and everything else. Several versions in all between summer 1963 and around 1967. Otherwise, if I see something listed I will let you know.
Dan Case
wcampbell
Dan - The car was converted to race after purchase in June 1965 so I'd figure likely bought over the counter starting late summer into fall of 1965. Earliest remembrance from the 2nd owner was in 1969 we he brought it home for the first time, but he doesn't recall details - only it's presence on the car so I'm going with a 5 bolt later production housing was in it.
Dan Case
Quote from: wcampbell on December 07, 2021, 06:40:57 PM
Later ones are much easier to come by.
Dan Case
