69 GT350 transmission fluid
Started by SChatman, September 03, 2018, 01:21:32 PM
SChatman
Recommended Transmission fluid, my car hasn't been running since the days of Type F. I've heard several opinions suggesting Mercon synthetic and people say no Type F.
Thoughts?
rhjanes
My local NAPA shows to still have Type-F on the shelf.  I had my C-4 rebuilt about 4 years back.  I asked the rebuilder and they said to use the Type-F or Mercon would also be fine.  I used Type-F from NAPA (Think it was Valvoline)
SChatman
I've found type F at the auto parts stores but the Transmission guys are saying the Mercon V is better and NPD sells Motorcraft Type F and Mercon V and charges more for the F. I haven't heard any reasons why one over the other yet, you'd think that rebuilders would be able say why.
Thanks for your reply
rhjanes
Up to you then.  I got to trying to recall my old memory tapes.  I think my tranny guys said the same as yours are!  I might have filled it with Mercon! I'd have to dig to see if I kept a receipt for the fluid.  I know I kept the rebuild receipt.  Anyway, if the tranny guys are saying Mercon V if good then go with it.  They should know the rebuild kit they used would be OK with either fluid.
KR Convertible
My local Walmart has type F for $2 something a quart.  The auto parts stores charge $5-7.
rhjanes
Quote from: KR Convertible on September 04, 2018, 10:44:44 AM
Is that the generic stuff?  Yeah, I've used it also.  Got a few quarts of it out in the shop.
zray
The best type F is the synthetic version of B&M Trick Shift
the 2nd best is the conventional B&M Trick Shift
These products are NOT additives, but a stand alone type F fluid.
Z
PS.   The above reccomendations are applicable to the fluid choise in the vintage ball drive Paxton supercharger..  my last Paxton had 75,000 + miles on it with ZERO maintenance other than changing the  synthetic B&M fluid fluid at every oil change. Numerous high speed endurance runs on the course of the Big Bend Open Road Race, 53 miles each way @ maximum rpm 95% of the time.  A fluid cooler was also installed.  If you have a Paxton this is the way to keep it from wearing out. At the time I sold the Paxton, I sent it to Craig C to have it checked out. He reported it had no wear and needed nothing.
SChatman
Thanks everyone fo the suggestions. I'm being told by the transmission experts that I've since talked to That say the Mercon V is better then Type F because it's updated with better additives and the synthetic is even better. Thanks again.
KR Convertible
Quote from: rhjanes on September 04, 2018, 08:42:41 PM
Yup.  The bottle says Supertech
Quote from: SChatman on September 05, 2018, 10:03:26 PM
+ 1
