Aluminum Engine ID Tag location - 351 Windsor
Started by BlackJadeGT350, March 23, 2022, 04:47:09 PM
BlackJadeGT350
Hi all,
I'm reviewing the MCA 1969 - 1970 Shelby Concours Trailered/Driven document and for the aluminum engine ID tag it says it needs to be in the correct location and visible.  Mine is attached on a bolt that holds the coil mounting in place.  It is not visible at all.  I'm trying to find a picture of where it should correctly be.   Based on researching online it sounds like mine is in the correct location. Just not seeing how it can be "visible".   I've attached a picture of mine.  To get this picture I had to wedge my phone where no human eye could see.
Anyone have a picture they can share with the correct location of the tag?
Thanks!
Eric
TOBKOB
1969 GT350 owned since 1970
As you have found - tough spot to get or take a picture of
Here is an example of one on an unrestored car. Hope this helps
BlackJadeGT350
Thank you, that does help. And thanks for the picture!
Eric
