Loud starter issue
Started by Milo, April 26, 2022, 07:36:35 PM
Milo
Hi guys -
Any of you ever experience a loud initial start up on a 68 GT500? It kinda screams when the starter engages. Fresh rebuild, maybe 1500 miles. I just replaced the (newish) starter with a new new one and the noise problem still persists... not the biggest deal, just kind of embarrassing.
Thought I'd phone a friend.
Thank you!
Milo
1972 Bronco Coyote
1968 F-250 Camper Special 390
Yes I have had this issue. The problem is a fairly common one, the bellhousing is bent. Typically from someone jacking the car using the bellhousing, or if someone has damaged the bellhousing by driving over something that is a little too tall.
It's hard to fix.
67 GT350
My 67 does that also, I was told either replace the starter or try shimming it? Horrible sound and yes embarrassing....
RARE  Signature Delete
