67 Shelby Parts for 289
Started by DavidGT350, June 09, 2022, 05:48:53 PM
DavidGT350
Updated post to include some additional items I need and thanks to all of the members that helped.
Trying to put my 67' GT350 together and need some engine parts.Engine was blown and original owner replaced with a 302. So starting from scratch with a correct dates block.
1. Hipo Rods C3AE - Found
2. Timing chain set - Found
3. S2MS Intake - Found
4. Timing cover dated late 66 thru Feb 67 - still need
5. Standard ford oil pan since the did not assembly line the T pan after 66' - Found
6. C7* Heads - Found
7. Fan shroud w/o AC (understand this is rare) - Found
8. Main caps -Still need
9. Camshaft - new item
10. Rocker arms - new item
PM me or send email to dmglover@sbcglobal.net if you have any of the above with pictures and asking price.
poboy427
You will need to research whether your build calls for thermactor or non-thermactor emissions C7 Hipo heads. What is the date range on  the heads you want? You will need to add to your search list a correct HiPo dizzy dated prior to engine assy date. You can add that after the engine is running as far as that goes. Same with carb and fuel pump.
good luck
Ray
6S554 Family owed since May 15,1974. Confirmed original alum T-10 4spd, MICO,
SPF 0373 Cobra S/C, Shelby alum 488 stroker FE Tunnel Port, TKO
He needs non-thermactor heads,  date codes before first week of February.
Quote from: DavidGT350 on June 09, 2022, 05:48:53 PM
1. Hipo Rods C3AE
2. Timing chain set
3. S2MS Intake
4. Timing cover
6. C7* Heads
8. Main caps
PM me if you have any of the above with pictures and asking price.
FYI the fan shroud is the same whether A/C or no A/C . You will have to provide a email address as you can not include pictures in a PM.
tater_51
Hi, Are you looking for an S2MS or S7MS intake?  Thermactor  or non thermactor heads?  What date on the heads?  I have a 67 engine I'm probably going to part out.  Let me know what date your looking for, I might have a lot of the parts you need.  Terry in Michigan
DavidGT350
Thanks for the replies in forum and PM's. Build date was 3/14/67. Unless there are other opinions need first week of March or before back to January. Heads, if I remember correctly, for the C7ZE are not date coded like the standard 289 but you guys are mush more knowledgeable than me. Found an S2MS and will be picking up today as long as everything matches the picture and thanks to the "engineer".  JD is correct non-thermactor and if there is a standard for date, 30 days or more before build date, please let me know. Dmglover@sbcglobal.net for pictures please. Appreciate the responses!
I think the first week of March is too late, the heads were cast in Cleveland Ohio machined and the engine built then sent to San Jose (Milpitas, CA) to be installed in the car, two weeks seems a bit tight.        (then sent to Shelby to be completed).
Heads are date coded, it is under the valve cover.
Image added, 6B25 = 1966 Feb 25th - as an example
also note for HiPo Heads screw-in rocker studs and recessed pockets for valve springs as well as other molded-in identifiers.
FYI there are numerous versions of S2MS intakes . They evolved over time . For example your build would be a little too early for the late S2MS with the large S2MS letters and extra threaded hole for mounting the coil on the intake and two holes on the rear runner for smog valve on the rear . The smog S2 is typically seen on later production then yours 67's. More appropriate would be the  S2 in smaller letters ,no extra threaded holes and COBRA with a slanted cut on the end by the "A".
A comparison of the two versions Bob is referring to:
brandosaac
I have 2 sets of Hipo rods
will send you a PM
