List 3259 65 GT350 Carb fitting
Started by mygt350, August 07, 2022, 06:13:29 PM
Drew Pojedinec
I think it has a W circled and some weird design.
Few would look close enough. I was hesitant to post my link as it isn't "correct"
Sometimes you just need to connect two parts
NC TRACKRAT
#16
If I'm not mistaken, two of this same adapter(or a variation of it) are used in the lower tank of the radiator to accept the transmission cooling lines from the C4....only it's made of steel, not brass.
5S071, 6S1467
mygt350
Please take look at NPd for part number T-9155-1k.That looks like it would work. What ya think?
Quote from: mygt350 on August 13, 2022, 10:59:32 PM
I just confirmed that it will work. I had a 64.5/65 Carter clamshell fuel pump and low and behold it had a fitting in it still. No markings on the fitting to report but I was able to compare with success that it will work as needed.
