Overstock Wiring Sale
Started by Coralsnake, November 12, 2022, 09:04:48 AM
I have to clean the overstock of wiring I have accumulated. All wiring is new, reproduction wiring made by Alloy Metal Products in the USA. It is original style with original plugs and wire colors/gauges. I do my very best to make sure people get what they want. Many of these harnesses are currently "out of stock" and hard to find. Sorry, I will not ship these outside the USA.
All harnesses are Mustang unless noted:
1970  Headlight harness w sportlamps   $150
!969    Underdash with Tach $950
1969    COUGAR Headlight Harness (non Eliminator XR7 Models) $150
1969    Drag Pak Jumper wires    $10
1969    Alternator Harness w/Tach      $35
1969    Clock feed  $20
1968    Small Block Alternator w/T   $ 30
1968    AM FM from radio to door speakers $20
1968    Heavy Duty solenoid to starter cable $20
1968    rear courtesy lamp and fuel sender (NON Shelby )   $20
1967    small block Alternator with Tach $20
1967    AC underdash auxillary  $25
1965    one speed wiper under dash $30
1966    auto shift feed $20
1965    2 speed wiper underdash
Year ?  convertible top feed engine bay to switch w/ 1" grommet $20
Other wiring available, please inquire and I will try to get you what you need.
Please also look at my NOS parts for sale:
https://www.saacforum.com/index.php?PHPSESSID=4avstdd0bngsbhklv421tbo0h0&topic=19936.0
Coralsnake68@hotmail.com
Hov
Hello Pete, I sent you a pm on a couple of your 65 harnesses. Thanks.
JohnSlack
Assuming that these are Mustang harnesses and not specifically "SHELBY" harnesses I need the "1969   Headlight Harness without Tach           $150"
Is this the harness that goes between the firewall connection to the under dash harness and goes all over the front end to the Voltage regulator et al.?
John
It is that harness, please email me directly and I will get you squared away.
Pete
Nonay707
hello CS can i get a set of the 65 battery cables? you can email me at preed4859@gmail.com
List updated thanks to all that purchased wiring
