3 spoke steering wheel pad touch-up or replace
Started by rdmgt500, January 03, 2023, 11:10:45 AM
rdmgt500
My steering wheel foam pad is pulling away from the metal base exposing some of the yellow-brown foam at the edges. Any thoughts on spraying the pad with black charcoal vinyl spray paint vs replacing the pad? Is this just a loosing battle? Thanks.
Quote from: rdmgt500 on January 03, 2023, 11:10:45 AM
They never used black charcoal as far as I have seen. vinyl black pad. I use a vinyl dye for center pads.
Quote from: shelbymann1970 on January 03, 2023, 11:21:37 AM
+1 . The vinyl pads were black from the factory. It is the dark plastic of the steering wheel body that is the very dark charcoal metallic.
rdmgt500
Thanks. Any suggestions for a black vinyl spray paint to use? Matte, semi-gloss, etc?
Quote from: Bob Gaines on January 03, 2023, 12:43:31 PM
+1 thanks for expanding on that Bob, I should have. I got a real NOS rimblow wheel on my Vert.
