428 Cobra Jet Engine identification
Started by rdmgt500, January 18, 2023, 05:54:02 PM
rdmgt500
Is it possible to verify a 428 CJ w/o seeing the block scratch letter? These are the numbers I've been able to find to date:
Block casting # C6ME-A (seems correct for '68-70 428CJ)
Engine block date code is "8G23" (July 23, 1968) also seems correct. Vehicle build date was 1/28/69 from the Marti report.
Cylinder head casting # C8OE-C090-N (seems correct)
Cylinder head date code: 8L8 = Nov 8th, 1968 (seems correct)
The vin stamping on the block is illegible. See pic below.
Thanks for the help.
The scratched letter on the block is only one indicator. It must be taken into account with other indicators.
If you're suggesting that a July 68 block came In Jan 69 built car, I would say its very unlikely
With regards to heads the C8OE-N is the correct 428 Cobra Jet head. While its possible the Nov head matches a January car, I feel that would need additional authentication
Shelbypat
Quote from: rdmgt500 on January 18, 2023, 05:54:02 PM
what is your VIN ? Mine's build date is one day after january 29
Patrick
rdmgt500
Shelbypat
